can you test outside temperature sensors
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by hammer head mn, Jun 3, 2011.
  1. hammer head mn
    hammer head mn Light Load Member
    209
    76
    May 29, 2010
    mn
    Have a KW with sensor in mirror that doesnt work.Is there way to check wire or the sensor itself.Do they have small voltage going thru them or how do they work? :biggrin_25520:
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    You try calling the dealer? They should be able to get ahold of a tech support line.
    Mark
  4. Hammer166
    7,458
    27,031
    Aug 18, 2007
    ~8600+' and loving it!
    Define doesn't work. If no display check for supply voltage, if display is on it's either the display or the sensor.
  5. hammer head mn
    209
    76
    May 29, 2010
    mn
    When it does show something its around 180 or hotter but most of time it just shows dashes where temp should be.No i havent talked to a dealer,usually try things myself first.
  6. Hammer166
    7,458
    27,031
    Aug 18, 2007
    Just realized I wasn't very clear--- if the display is on and displaying non digits, it's the display. What you have sounds like just a sensor, although it could be wiring. The dashes normally mean out of range, so the display is getting faulty info from the sensor. I'm not familiar with those units; are they one piece in the mirror, or are the sensor/display two separate pieces? If 2 pieces, check the connections between them.
  7. hammer head mn
    209
    76
    May 29, 2010
    mn
    sensor is in bottom of mirror and display is in dash.Suppose i better figure out how dash comes apart to get to wiring.
    Thanks for the help
  8. Hammer166
    7,458
    27,031
    Aug 18, 2007
    I'd look at the mirror end first, out in the elements, etc, etc
