Canadian Spread
Discussion in 'Trucking Industry Regulations' started by lauvertrucking, Feb 9, 2009.
  1. lauvertrucking
    lauvertrucking Bobtail Member
    Mount Pleasant Mills, PA
    Can anyone give me a concrete answer on the weight tolerance on a "Canadian Spread?" A canadian spread is an option Freightliner gives to spread the drive axles from 51" centers (standard) to 59". This is supposed to increase the allowable weight of 34,000 lbs to 35,000 lbs. If you follow the FMCSA's bridge formula and put all the numbers into the equation for 59" the answer is 35,000 lbs. However, just got fined for being 34,800 lbs on the drives in VA. Thanks for any help.
  3. 25(2)+2
    18,749
    45,467
    Sep 18, 2006
    the road less travelled
    News to me, I thought speads were om trailers, we have some converted to 10 foot spreads from the Canadian spread. If your tractor has 59" spread on the drives and Maryland doesn't have a special reg for that, too, then take it to court, it might be worth it. They do have some special rules no one else has, though.
    Welcome to the Forum.
  4. KCCW
    KCCW Bobtail Member
    29
    10
    Dec 31, 2007
    Littlefork, MN
    According to the Bridge Formula Table in the RM Motor Carrier atlas, anything less than 8 feet is a " tandem axle by definition " , and is allowed
    to carry 34000 #
  5. witchwaywest
    witchwaywest Medium Load Member
    327
    105
    Dec 8, 2007
    Monroe New York
    Virginia law limits tandems to 34,000 lbs. but you can buy a multi trip,yearlong overweight permit .If you don't go into VA much you can buy a single trip permit .If you haul certain commodities you can get a permit for free.Sealed containers to or from a port also haulers of coal,sand,gravel,stone and gas or oil with some restrictions.I wouldn't wait to long though.The VA DOT is proposing higher trip permit fees for overweight trucks.Go to VDOT and search under "certifications and permits".This will list permit fees and the weight formula for determining permit costs.The permits are cheap right now but if VA DOT gets its way you'll see a huge cost increase.
