Canadians - Lift Axles in Canada / Front axle weight
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Sep 23, 2016.
  1. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    Hi there. Can someone explain which provinces allow lift axles from the west (BC) over to Ontario (Qbec if you know as well) Also, what about wheel base with the lift axle. Are there exemptions for US Trucks.
    Are US Trucks allowed with heavier then 12.5 front axle. What about a 16K front axle.
  3. nate980
    nate980 Road Train Member
    2,020
    5,225
    Dec 23, 2010
    Langley BC
    Well I know BC, AB, SK, MB won't allow lift axles on trucks. We all run tri drives. Only wheelbase exemptions are for true tridrives and or specialty trucks with winches and pickers etc. Yes you can have a 16K front axle.
  4. UltraZero
    406
    96
    Jul 18, 2013
    Is that they won't allow lift axles on the truck, or won't allow the lift axle on the ground.???
  5. AModelCat
    154,966
    I would assume they are ok to be on the truck out in BC/AB. Just not on the ground though. I see CanAm trucks running through there all the time with the lift axles up.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Yup I go to BC quite a bit. 12 on the steers and 37 on the drives with the lift up.
  7. nate980
    2,020
    5,225
    Dec 23, 2010
    Langley BC
    Won't allow them on the ground.
  8. Razororange
    Razororange Road Train Member
    2,458
    23,288
    Dec 20, 2011
    Milwaukee, WI
    As for wheelbase I know for sure that BC and AB will let you buy permits for US trucks with a WB over 244". I can't remember the exact cost but it wasn't anything absurd. We have to order them anytime our trucks go up there because we run 3 Pete 379s and a W900 that all are over 250" WB. My T880 is even longer at 264".
    I think AB was something like $30 per year for our entire company and BC was around $80 for a 30 day permit.
  9. nate980
    2,020
    5,225
    Dec 23, 2010
    Langley BC
    Best bet is to just phone the delta bc scale and the scale in Leduc Alberta to get the guaranteed answers. I forgot about the permit for bc/ab.
  10. RGN
    RGN Road Train Member
    1,360
    14,186
    Jun 13, 2014
    Last I checked I can go to BC with mine- but the lift has to be chained (lifted up) prior to entry. Been awhile, things may have changed.
  11. old iron
    old iron Road Train Member
    1,126
    19,701
    Feb 19, 2011
    Northern Wi
    Keep in mind that a permit for an over length tractor voids your ability to permit for oversize.
    It also shortens the allowable wheelbase for your trailer. There is a sliding scale for up to I think a 280" tractor. Trailer wheelbase drops to around 38'. Not that big of a deal with a box trailer sliding tandem but good luck with an open deck trailer.
    I finally shortened my truck to 244". And it still pisses me off.
    Ruthless Thanks this.
