Cannot adjust a Kwik-Adjust clutch, it is stuck!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ichudov, Oct 22, 2014.
  1. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    We have a 2000 Freightliner FLD with a Kwik-adjust clutch.
    The problem we are having is that the clutch stop is not working. So we started looking.
    Upon inspection, we found that the throwout bearing does not contact the clutch brake even if the clutch pedal is pushed to the metal.
    We tried to adjust the clutch, which has a special Kwik-Adjust clutch adjustment system.
    Pushed the nut in as instructed, it does engage the inner ring gear when pushed in, however we were unable to turn it.
    Any idea why? Thanks!
  3. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    Are you having someone hold the clutch pedal to the floor when you are trying to adjust it? No mention of it in your post so I thought it was worth mentioning. Sometime the adjusters can get pretty froze up as well.
    ichudov Thanks this.
  4. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    We did not hold the pedal. Now I feel like a total idiot. Thanks
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    as the famous comedian said----- HERE'S YOUR SIGN!
  6. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    OK, thanks. With the clutch pedal pushed in, the clutch adjusts.
    The sad news, however, is that the clutch is worn paper-thin, and will need to be replaced.
  7. StrongArm
    StrongArm Light Load Member
    50
    11
    Apr 2, 2014
    New York, NY
    Did that one time when I was adjusting the clutch by myself. I use a plank or 2x4 of a broken pallet and shim it until its floored.
    This one time I was rushing to adjust it before I pull out for the day, I tried to turn it and freaked out, thinking that there was no adjustment left in it. I then realized that the pedal wasn't floored. That was a relief.
  8. tmslogistics
    tmslogistics Light Load Member
    138
    15
    Mar 10, 2015
    So if I follow all of the procedure and it still won't adjust, is my clutch gone??
  9. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Adjust pressure plate ring until you have approximately 1/2" between throw-out bearing and clutch brake. Next, you will need to adjust the linkage to obtain correct free travel. BUT, before you do anything verify cab ride height because it affects your clutch linkage geometry and make sure ALL the Heim joints on the linkage are good and not worn out, this too will affect adjustment. Ideally if a clutch is adjusted correctly at time of install you should only have to adjust the pressure plate to obtain free travel and in turn will move the throw-out bearing within spec in regards to the clutch brake.
    Edit to add.....most 3/8" extension shafts are roughly .500" so that should get you in range for proper clearance between throw-out bearing and clutch brake.
    Mr.X Thanks this.
  10. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    I think Tony is right on the money! Except I was taught to ensure there was no more than 9/16" tollerance between the surface on throwout bearing and the clutch brake friction (which on a high mileage truck is normally worn off and just shiny steel).
    I have always used a long bolt with 7/16" head on it to measure that tolerance. You should never have to adjust clutch linkage, unless something is broke or bent.
  11. tmslogistics
    138
    15
    Mar 10, 2015
    Gotcha. So if it will no longer adjust....is my clutch gone?
    Thank you,
    Toby
