can't adjust clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stonefly4, Jun 27, 2019.
  1. stonefly4
    stonefly4 Light Load Member
    162
    122
    Oct 4, 2018
    93 FLD 120—sitting 41/2 years
    5/8" clutch adjusting bolt won't turn
  3. buddyd157
    buddyd157 Road Train Member
    13,538
    34,690
    May 25, 2017
    under a shade tree
    spray the crap outta it with BLASTER
    Blastercorp
    Rideandrepair Thanks this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm just going to say it. Is the clutch pedal pushed down when your trying to adjust it??
    Also you are pushing down on the lock retainer so bolt will turn correct??
  5. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    have you ever done clutch adjustment before ?
    BoxCarKidd Thanks this.
  6. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    and sometimes the piece around bolt must be pushed in.
  7. stonefly4
    162
    122
    Oct 4, 2018
    Yes. Did that. Still no go.
  8. stonefly4
    162
    122
    Oct 4, 2018
    Yes. I jam a stick between the pedal and the seat.
    I pushed in the lock retainer. At first it was stuck, but I freed it and pushed it in. The clutch won't adjust. When I push hard on the breaker bar adjuster, the engine turns, not the clucth adjusting ring.
    Rideandrepair and swaan Thank this.
  9. stonefly4
    162
    122
    Oct 4, 2018
    Yes. I've adjusted this one numerous times, but I took it off the road and it's been sitting a long time. I need to put it back on the road. I think maybe the clutch adjusting ring is rusted and frozen. —Just wundrin' if anybody else has dealt with the problem.
    I have two trucks with this type of clutch and over the years I've done more than a dozen adjustments between the two of them, but this is the first time this has happened.
  10. stonefly4
    162
    122
    Oct 4, 2018
    Thank y'all for the replies!
  11. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    like buddyd157 said spray it and drive a little in city. then try it again.
    stonefly4 and Rideandrepair Thank this.
