Can't find the ignition timer
Discussion in 'Kenworth Forum' started by Jgedwards, Feb 6, 2018.
  1. Jgedwards
    Jgedwards Bobtail Member
    Can anyone help me figure out how to find the ignition timer on my brand new T880? I've driven a 2016 and all I had to do was turn the selector knob to it and select it and select how long I want it to idle before it shuts down. Is it a programming issue? Is there something stupid that I'm missing?
  3. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    It probably doesn't have one, that is optional equipment
  4. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Its on the selector knob if it was ordered from factory. If you want to install one it needs to be programmed in the cecu then a harness installed
    Jgedwards Thanks this.
  5. Jgedwards
    Thanks! I actually contacted kenworth about the programming and was told that it no longer exists and if you currently have it, the next time your computer gets updated it goes away
  6. OnTheLevel357
    OnTheLevel357 Light Load Member
    86
    51
    Apr 9, 2017
    anyone know if there's a way to still run the ac or heat once you've enabled your timer?
