Can't get truck to uncouple from trailer......
Discussion in 'Questions From New Drivers' started by Brutal Rattler, Jan 9, 2012.
  1. Brutal Rattler
    Brutal Rattler Light Load Member
    95
    4
    Oct 28, 2011
    Apple Valley, CA
    So I had to drive a truck recently that I don't normally drive. Today I went to uncouple the truck from a trailer that has a load on it for me for tomorrow. I can't get the release lever on the 5th wheel to unlock. I tried all the normal lowering and raising the landing gear and bumping the truck forward and backwards to relieve the pressure on the kingpin and I still got nothing as a result. I have to take that load somewhere tomorrow morning and if I don't get to switch the trucks im screwed on a good running truck....Any tips that may work?
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    I'm not going into much detail. This has been an ongoing problem with our new trailers for me.
    Before doing anything else. Step out and push the handle in. YES I know it's in the locked position. Then apply backward pressure. Release... This has worked best for me.
    Other than that, slam the hell out of it several times.
    You might try turning the truck slightly left or right.
    davetiow Thanks this.
  4. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Apply trailer brakes, back up against the fifth wheel and while holding the tention apply the tractor emergency brake. Try pulling the lever now.
  5. Brutal Rattler
    95
    4
    Oct 28, 2011
    Apple Valley, CA
    Yeah im in a dirt lot too so I know being on un-level ground there might be a bind in the kingpin too. So maybe I should pull up a few feet as well?
  6. Brutal Rattler
    95
    4
    Oct 28, 2011
    Apple Valley, CA
    That is what I meant about bumping the truck forwards and backwards
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    see if the handle doesnt have to be lifted up about 1/2 inch in the slot where it comes through the fithwheel some have a stop welded on them to keep them from coming out.
  8. Brutal Rattler
    95
    4
    Oct 28, 2011
    Apple Valley, CA
    Yeah ill check that too. I also saw somewhere that some trucks you have to pull the lever to the left some and pull at the same time
  9. Moosetek13
    Moosetek13 Road Train Member
    14,585
    18,184
    Nov 1, 2010
    Burnsville, MN
    My current truck can be difficult to release as well.
    I have to pull up on the handle a bit to get it to lock open.
    You know, it could simply be worn out.
    If it won't release with any of the suggestions put forth so far - then call it in and have some service done.
  10. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Probably not a solution to your situation but:
    A lot of our trailers creep forward when you set the tandem brakes. I have found that if you set both brakes at the same time it sometimes binds up the 5th wheel release lever.
    Setting the tandem brakes and waiting for the trailer to settle. Then set the cab brakes seems to help.
    Mikeeee
    davetiow and OmcCheese Thank this.
  11. cpttuttle
    cpttuttle Medium Load Member
    399
    178
    Oct 20, 2011
    altoona,pa
    or walk around to the pass. side of 5th wheel and look for what looks like a bolt head and hit it with a hammer then walk back around and make sure handle is out.that worked for me before.
