cant locate turn signal flasher pls help
Discussion in 'Questions To Truckers From The General Public' started by roadrunner2012, Jan 4, 2012.
  1. roadrunner2012
    roadrunner2012 Bobtail Member
    21
    philadelphia pa
    I'm driving a 05 kenworth t600 I'm in the middle of a trip and drivin with no turn sigs or 4 ways. Can't find the location of thos flasher for the life of me..I checked fuse box, nothing. I was told to check behind the dash on the side of glove box and I did with no luck. Anyone know where its located?
  3. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    I am not sure how the kw is set up. But Make sure they are pluged in good where they connect to the bottom of the signal arm if it is similar to the picture below.
  4. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    The flasher should be in the relay panel. It looks just like all the other relays.
  5. Crusty
    Crusty <b>Just Plain Crusty</b>
    345
    140
    May 29, 2010
    Canton, GA
    Googling up a PDF manual on that model would probably help.
  6. roadrunner2012
    21
    philadelphia pa
    Yea I have the manual..its not in any of the 3 spots it says to check....also I have the replacement relay..its def not in the relay box..all of the relays in the box are half the size
  7. bostonbull
    bostonbull Bobtail Member
    17
    Jan 14, 2010
    massachusetts
    check under the dash to left of the steering column
  8. roadrunner2012
    21
    philadelphia pa
    Yea thats where I ended up finding it...previous owner had it tucked away...flashers still not working tho..must be blown fuse..thanks for the help guys
  9. XRESETX
    XRESETX Bobtail Member
    15
    10
    Sep 4, 2012
    I went thru this entire thread for an answer to my 2006 T660 no Flasher/Turn Signals, watched every available video on the net and FINALLY figured it out AFTER taking the truck to the Stealership and getting horsefreaked out of $560 and STILL had no Turn Signals. OK, the deal was I swapped out the batteries and my ratchet handle hit the side of the box while on the positive post and sparked ONE TIME. That's all it took. Yeh, shoulda, coulda, woulda made sure the ground was disconnected first, but I didn't. Anyways, be sure to check all the fuses and relays in your fuse box and eliminate that possibility, then in the CENTER of the Dash--pull off the plastic bezel around the instrument cluster and unscrew 4 screws and pull out the panel and look for a 6" x 5" black box with a dark blue front with 2 plugs hanging out--the entire box is NOT secured, just hanging deep in the dash, about where the cup holder is. The part number varies by a single digit, but mine is: P21-1019-303, PACCAR. Others end in -203 and -103. On Ebay and general search on Google, the price for this "PC/ABS" module varies from $450-$600 and surprisingly, a new one is "only" $606 after taxes from the Stealership. Plug 'n Play--so for $1160 later, everything works. The worst thing was the truck wouldn't start right after the battery incident, took it in to the Stealership, they got it to crank, but the Turn Signals were going to be a separate issue and an additional charge and their fancy computers were unable to diagnose the module failure, so I was going to be charged time and material for the FNG new hire to find the problem @$125/hour. The joys of trucking, part #109936471...
    allniter and x1Heavy Thank this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Jaysus, we used to swap out the big signal box on the turn handle at the steering column back then and replaced lights as usual.
    Stupid engineers. Over thinking everything. Simple is good. And strong.
