Carrier or TK
Discussion in 'Ask An Owner Operator' started by mromgcorey, Apr 15, 2022.
  1. mromgcorey
    mromgcorey Bobtail Member
    21
    11
    Apr 15, 2022
    I live in Texas and have been looking into buying an APU for the summer heat right around the corner.
    I currently have a 2018 t680 and there is not a whole lot of room behind the fuel tanks making my decision a bit more complicated.
    TK told me they could install there unit on the passenger side by moving the fuel tank back and mounting the unit under the side panel hidden away. With everything said and done, it would end up being 4k more than the carrier.
    Carrier dealer has reiterated to me that they could fit the unit on the frame and all that would be needed is to move the fuel tank forward an inch or 2.
    With that said, the carrier will be much easier to work on than the TK as well as checking the oil. Should this be a concern of mine? Or is it better that the TK is hidden and tucked away under the passenger side panel?
    As of right now, I'm still conflicted. I hear more negative things about the carrier than the TK. I want to ask you guys what your opinions are on each unit and if the TK is worth the extra 4 thousand dollars.
    Thanks
  3. Arctic_fox
    4,502
    25,382
    Sep 16, 2016
    Honestly its dealers choice. TKs are in my opinion and experince FAR more reliable on average, cool better and are a lot easier to work on and diagnose when they do break. They have a lot more very good options such as a larger altinator or standalone system. They also have a lot of aftermarket parts that make them even better.
    However they are a lot more expensive to maintain, getting parts can be very hard, and they require you to stick to the maintaince schedule if you want that reliability. They require a laptop to be able to access the computer diagnostics and they tend to eat altinators if you max the load out a lot.
    Carriers well they are a lot cheaper, easier to get parts are a tiny bit more fuel efficent and are smaller overall. They can handle going without maintaince better then the TK models and are a bit more strudy in construction.
    However they tend to break down a lot. Can be hard to diagnose, dont cool for #### from my experonce with the 5 i have used, have a nasty habbit of eating rings from what i am told are way louder and tend to vibrate the truck a lot more then the TK models do. Also this is subjective but i can smell a lot more unburned fuel when im around a carrier then my TK.
    DirtyBob Thanks this.
  4. mromgcorey
    21
    11
    Apr 15, 2022
    As far as I know, the TK are actually more fuel efficient. I've been told the TK burns 1 gallon of diesel per 10 hrs where as the Carrier is around 2-3.
    Does the warranty cover alternators?
  5. Arctic_fox
    4,502
    25,382
    Sep 16, 2016
    My experince has been the reverse on the TKs BUT i also have an older used unit so it could just be mine is old and has lost efficency compared to the brand new carriers i have used in the past. As for the warranty i think so yes. But i am unsure as like i said mine is pretty old and was used when i got it.
  6. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,031
    Dec 31, 2010
    Washington, PA
    If you have a condo, the Texas heat makes any APU work half well. Actually any hot summer heat. Just doesn’t have enough cooling. Better off with a gas generator and some type of higher BTU AC set up. Just my opinion.
    flood, goga and bzinger Thank this.
  7. Upstatetrucker
    Upstatetrucker Bobtail Member
    29
    96
    Nov 15, 2020
    I have a 2018 T680 and there is plenty of room with the TK Evolution behind the tanks to check the oil and open the hatch. I will try and get a pic tomorrow when I'm back in the truck. It may be the fuel tanks I have are smaller as the TK came factory installed. As for service all I've done is oil changes twice a year.
  8. mromgcorey
    21
    11
    Apr 15, 2022
    On a new unit, do you still wait the 2000 hrs before maintenance or do you need to go sooner like you would for a new car?
  9. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    The TK’s run colder but IMO carriers are more reliable. Also when I had a TK it was just a knob while carriers had an digital thermometer that also showed the current cab temperature. Carriers are louder so I opt to have it run the whole night instead of having it on start stop so it can be filtered out. I personally like the carriers more cause it comes with an alternator and a generator while the TKs is just a bigger alternator. Another issue with the carrier is the way it was engineered you can’t have any Joe Shmoe touching that thing they will break it. If you do opt for the carrier when it’s a hot deal pre cool the cab with the main engine’s ac unit then use the apu engine’s unit to maintain the temperature and shut the sleeper curtains
  10. Ffx95
    1,370
    2,635
    May 18, 2017
    Book says service every 2k hours but I will tell you if you don’t want problems with the carriers do it every 1k-1.4k hours.
  11. mromgcorey
    21
    11
    Apr 15, 2022
    Are there any upgrades for the carrier like the air tower for the TK?
