Carrier Reefer help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by max954rr, Sep 3, 2023.
  1. max954rr
    max954rr Bobtail Member
    11
    8
    Mar 29, 2022
    I have a 2014 carrier x4 7500 that the alternator won’t charge unless I excited it manually.
    Changed alternator twice, and does the same thing. any ideas why it won’t start charging on its own.
    Thank and await any reply’s
    KB3MMX Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,366
    6,225
    Nov 16, 2013
    Baltimore, Maryland
    @reeferwrencher
  4. bzinger
    bzinger Road Train Member
    16,635
    66,093
    Dec 10, 2014
    omaha , ne
    Bad board or ecm would be my guess .
    KB3MMX Thanks this.
  5. wichris
    wichris Road Train Member
    4,424
    9,056
    Jan 17, 2011
    The correct alternator? There are two different ones
    KB3MMX Thanks this.
  6. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    You kind of answered you own question.
    It is not getting juice to get it to charge so I would start tracing the wire back to see where it might be broken or why it is not getting power.
    You could even run a new wire for a temporary fix to get you by until you can get somewhere to fix it right.
    KB3MMX Thanks this.
