Cascadia 12v sockets won't output their rated output unless the engine is running
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by dieselfuelonly, Jun 18, 2013.
  1. MsJamie
    MsJamie Road Train Member
    Actually, both circuits are still fused at their rated current, so there shouldn't be any hazard.
    What's happening is that with the two sources, the power (and current draw) is divided in half for each outlet. Half the current means half the voltage drop, which supports my theory that it was a low voltage problem and not a current problem.
  3. claytonr1973
    claytonr1973 Light Load Member
    266
    289
    Jun 1, 2008
    miami,ok
    What kind of laptop are you using it with? When I had a M17x mine would do that with the dual 280s but my other laptops are fine.
  4. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Kinda forgot about this thread... lol. I ended up ditching the cheapo inverter and bought a nice Tripplite one that works perfectly with my laptop on the single 20A 12v socket, even when the truck is not running. The laptop is based off the Clevo P150EM platform, running a Radeon 7970M and a quad-core i7 3630QM, it will use a LOT of power, I believe the power adapter is rated for 180W.
    I'm guessing the higher-quality inverter is much more efficient and therefore doesn't need to draw as much in order to supply enough power for the laptop.
