Cascadia 2010 dd15 no power on ignition fuse
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mady, Nov 1, 2024.
  1. Mady
    Mady Bobtail Member
    Hi everyone I have cascadia 2010 dd15 engine that was stopped on highway ..when I turn ignition there no power on dash and no crank ..when I checked fuse box there is no power on ignition fuse 24-25-I puted power on this fuse so power is coming on the dash but still nothing cranking even I put power directly on the starter selonoid .. checked power and ground before Sam cabine and Sam chassis that coming from cut off switch,are good.I checked cpc and I changed Sam cabin but nothing changes..I really confused ..any suggestions please will be helped .appreciate
  3. MandS
    MandS Bobtail Member
    Hi Mady,
    Joell here! Do you have a VIN and is the fuse location call out #24? Kind of confused by the 24-25, are you saying its call out #24 and 25amps?
  4. MRMTRANS
    MRMTRANS Medium Load Member
    393
    428
    Apr 28, 2015
    ECM fuse at battery box?
