Cascadia 2020 low power when climbing hills
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Trucker1992, Nov 23, 2021.
  1. Trucker1992
    Trucker1992 Bobtail Member
    I just bought a 2020 cascadia with just under 500k miles. On my first trip with only 15,000lbs in the box, i cannot climb hills over 45mph.
    Im not sure if this is a dpf problem or something to do with the turbo. This truck does not have a boost gauge.
    Soot level shows good.
    Also, truck eats coolant when climbing hills. If i drive on flat roads, coolant will not go low.
    Any advice helps.
    Thanks
Draft saved Draft deleted
