Cascadia abs problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerGST, Mar 31, 2016.
  1. TruckerGST
    TruckerGST Bobtail Member
    9
    2012 cascadia dd15
    Active fault
    brake 011 spn 000810
    speedsignal in 14
    Abs light stay at ignition on
    Try to clear the fault no luck
    If going over 50 mph warning pop up on screen
    Abs activated+ road surface
  3. TruckerGST
    9
    Brake 011 spn000810 speedsignal in 14
  4. TruckerGST
    9
  5. Viola4lfe
    Viola4lfe Bobtail Member
    Woodbridge VA
    No one has fix for this?
  6. Viola4lfe
    Woodbridge VA
    In a 2013 abs light stays on. Had it checked at a loves, was told sensors are fine it has to be something in the harness and would need to take it to the Freightliner dealership. This fault is new. Was only spn 001590 adaptive cruise. Can clear faults but abs light stays on
  7. Brandt
    Brandt Road Train Member
    4,441
    6,025
    Sep 17, 2012
    ABS lght can come on if wheel bearing is lose, because the sensor can't read the wheel speed anymore. I had that happen in 2000 Volvo
