cascadia and prostar
Discussion in 'Questions From New Drivers' started by 4noReason, Jun 10, 2013.
  1. 4noReason
    4noReason Road Train Member
    2,377
    731
    Nov 29, 2012
    hey in length wise. how much bigger is the cascadia? i traded my prostar for one but i didnt really want a bigger truck i wanted one with better steering and easier to move around . also the steering wheel feels quite heavier than the prostar when backing.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    All depends on your BBC, size of sleeper, WB. IF you are comparing a std. length BBC's with condo sleepers (what most large fleets are running), they should only be a couple of inches in difference, I believe the Cascadias run a 72" sleeper and the Prostars are 73" outside dims are almost identical.
    airforcetoo Thanks this.
  4. sharp.dressed.man
    sharp.dressed.man Heavy Load Member
    701
    507
    Dec 10, 2011
    IL
    In my opinion the cascadia is not an upgrade in the areas that you mentioned. More space inside though for sure.
  5. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Kind of late to be asking now, isn't it?
  6. airforcetoo
    airforcetoo Heavy Load Member
    892
    216
    Oct 4, 2011
    Up in the air
    I Trained in a brand new prostar ... I like the cascadia better ...they seem to pull better
  7. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Did they have the same Engine.
  8. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Cascadia's will either have the D13, D15, or Cummins or Prostar will have Maxxforce or Cummins
  9. bigkev1115
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    I wished I had an ISX in my Cascadia. I drove a ProStar with an ISX and that thing would pull any hill with ease. Don t get me wrong, my D15 pulls great as well but after awhile of pulling a long grade, the D15 starts to lose power and forces you to downshift unlike the ISX
  10. airforcetoo
    892
    216
    Oct 4, 2011
    Up in the air
    The prostar I trained in had a maxxxforce then the first cascadia d15 then a d13 (BTW which is better 13 or 15?)
  11. KANSAS TRANSIT
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Definitely the 15, 13 is a lot smaller, and not any more fuel efficient.
