Cascadia burning excessive coolant. HELP!
Discussion in 'Freightliner Forum' started by Florida Playboy, May 22, 2014.
  1. Florida Playboy
    Florida Playboy Road Train Member
    4,102
    6,621
    Dec 19, 2012
    Florida
    I am driving a 2012 Cascadia with a red Cummins motor and the truck goes through over a gallon of coolant every 1,000 miles. It isn't leaking out anywhere so the motor must be eating it. Any ideas? Truck only has 357,000 miles on it.
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Take it to the dealer, It will not get better, and if they prove you waited and it grenades you could be held responcible.
    Just a thought!
  4. Dinomite
    Dinomite Road Train Member
    4,092
    4,308
    Sep 6, 2012
    Looking 4 Rocks
    Classic DPF/EGR Issues. You have white smoke coming out the exhaust as well. Get it to a Dealer or cummins shop and be prepared to spend a few days getting it fixed, and It probably will go bad again in less then 100,000 miles. All the antifreeze is coming out the exhaust stack. I stopped putting antifreeze and started using water until I was able to get it to a shop to save a few bucks. .
    tow614 and Steeleandsonfarms Thank this.
  5. stevict
    stevict Bobtail Member
    5
    May 20, 2014
    I hear Cummins has a problem with the EGR Cooler leaking. Coolant leaks into egr system and thereby into combustion chamber(s).Occasional white smoke from stacks if it gets a good burst but otherwise hard to pin down.
    tow614 Thanks this.
  6. tow614
    tow614 Road Train Member
    3,759
    4,630
    Mar 18, 2013
    This was a constant problem at gordon. Egr most of the time but I did have a blown head gasket once.
    Thats why they changed to detroits.
  7. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    know a 2013 that just got a new head gasket.
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Yep, first thought was EGR cooler. Extremely rare it would be head gasket. And unless there is evidence of coolant leaking around a connection or on the ground, EGR cooler is the primary target, then a head gasket. The first is easier to check. It can happen, though not very frequent, the ISX VG turbo could be eating the coolant. They are water cooled.
    Bosscity318 Thanks this.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    longer you wait to solve problem the more likely it is to have engine damage or dpf problems
  10. whskypete
    whskypete Bobtail Member
    28
    Sep 17, 2013
    I would lean towards the EGR cooler, they tend to leak into the exhaust side and over to the intake (Exhaust Gas Recirculation). Remove the crossover hot pipe and run the engine at idle or high RPM's. If you see coolant or a diesel like substance the there is water present. The coolant and soot mixed look like diesel but without the smell.
  11. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Fully expect the DPF to need replacing soon after you get the EGR cooler fixed! The coolant messes up the DPF .
