Cascadia DEF problem.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 3ARTransport, Apr 10, 2017.
  1. 3ARTransport
    3ARTransport Light Load Member
    106
    48
    Feb 6, 2016
    2011 cascadia dd15 and keep getting def quality and scr nox sensor low, codes. The def light starts blinking and slight derate. Codes are eec 61 Spn 4364 fail 18 and eec 61 Spn 3364 fail 02. I started having problems at the beginning of my trip but did a parked Regen and that got me 340 miles. Problems came back stoped at dealer and had Freightliner update ACM and do parked Regen and all was good for about 100 miles, still popping up the same codes. Regen was all normal and within specs, I'm wondering if anyone had same issue with this. Oh and def is good.
  3. 3ARTransport
    106
    48
    Feb 6, 2016
  4. medseg2003
    medseg2003 Bobtail Member
    26
    7
    Aug 11, 2017
    i am having same problem like you do, the only difference is that i have cummins isx 15 went to the shop 4 times for those codes, they keep coming back after 20 miles driving out of the shop, it's a headache and i guess the only way is to delete that crap that what other peaple told me, let me know if you find the problem and if u got it fix thx
  5. Two wolfs
    Two wolfs Bobtail Member
    9
    Jun 29, 2018
    Well, i have the same problem going on for 7 months, change one box, def metering unit, new def filter , def header, nox inlet and outlet sensor, every single sensor that has something to do with the def and I still have the same problem def quality code ... please help if you have any info?
  6. AModelCat
    161,299
    Have you actually tested the DEF you're using? Just because you buy it from a reputable location doesn't mean its any good. I know guys who've bought a bunch of DEF jugs from a dealership and they all failed the quality test with a refractometer.
    Oxbow Thanks this.
  7. Mike A
    Mike A Bobtail Member
    8
    I'm having the exact same problem right now, Did you get the problem resolved?
