Cascadia Evolution DD15 2016 steering axle 9000 lbs
Discussion in 'Questions From New Drivers' started by Asttiac, Apr 1, 2018.
  1. Asttiac
    Asttiac Bobtail Member
    44
    11
    Mar 28, 2018
    Hello! I’ve just purchased Freightliner Cascadia Evolution 2016 year (dd15) and have a question:
    I have only 9-9.9k lbs on my steering axle with 44k lbs load, my 5th wheel moved all way to the front and it’s still 9.9 lbs on steering axle. Why? Something wrong? Plz help, I’m have little experience with that, worked as a company driver for 2 years.
  3. Asttiac
    44
    11
    Mar 28, 2018
    And I tried to adjust my tandems to make axle weights legal, but I can’t, still have 34 on drivings, and 35 on trailer tandems, I guess loaders overweighted my tail.
  4. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
    I assume its not a daycab and we have the same truck. Mine is 11.4k on the steers empty. Unless you are not releasing the brakes when you are on the scale i dont know how those weights are possible.
    fargonaz Thanks this.
  5. Asttiac
    44
    11
    Mar 28, 2018
    It has sleeper, and the weight is as I said. I don’t know why... any ideas?
    Ps. I release brakes on scale.
  6. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    If you just bought,one of the first things you should have done was get an empty weight scale for your new truck. Now you don't know if it's your truck or the load.
  7. Asttiac
    44
    11
    Mar 28, 2018
    I said empty steering weight is between 9 and 10k
  8. Asttiac
    44
    11
    Mar 28, 2018
    The question is - is it a problem? 9k is ok, or it’s not?
  9. Asttiac
    44
    11
    Mar 28, 2018
    maybe 5th wheel was installed too far from cab and needs to be moved closer?
  10. Southlover
    Southlover Bobtail Member
    11
    12
    Dec 9, 2017
    Your tail is not overweight bcz u already have 34 in front . When is overweight the tail the front is low. Did u go to the scale to check ur total weight? Maybe u are 44000+ and more than 80.000 total
  11. kemosabi49
    10,457
    44,523
    Jan 13, 2013
    SW Arkansas
    Tha may well be. Where is the trailer kingpin at above your drives?
