Cascadia exhaust question
Discussion in 'Freightliner Forum' started by Wild Murphy, Jun 14, 2015.
  1. Wild Murphy
    Wild Murphy HAPPY TRUCK DRIVER
    942
    779
    I have seen Cascadias with a stack on the back and Cascadias with the exhaust coming out under the back. Is this from different years? Can you convert from having a stack to the other way? Also, any reasons to prefer one over the other?
  3. Grumppy
    3,175
    11,083
    Dec 11, 2010
    West Monroe, La
    I've got a 2015 & the exhaust is under the vehicle. I am assuming its just another way to reduce wind drag & increase fuel mileage to comply with government regulations. :dontknow:
    Wild Murphy Thanks this.
  4. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    I'm sure you can have it converted. I have a '15 Cascadia EVO and its underneath. I'm sure the explanation is that it's for aerodynamic reasons, and a space saver. Heck there isn't even an easy access to place a simple antenna for a radio.
    Good luck
  5. RSQ20
    RSQ20 Medium Load Member
    The reason for the stack is to get the fumes above the 4 wheel traffic...
    ... Philip
  6. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    They went to the weed burner , it saved about 300 lbs.
  7. Boardhauler
    Boardhauler Road Train Member
    1,732
    3,670
    Dec 21, 2008
    Ballin' in it for Shakey
    I converted mine to a weed burner with no issues.
  8. Wild Murphy
    942
    779
    What kind of time and cost?
    tucker Thanks this.
  9. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    don't convert it. you will have a little higher output pressure reading. the acm and 1-box is calibrated for short exhaust pipe.
    Wild Murphy and 25(2)+2 Thank this.
  10. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    The older ones with a 60 Series were more likely to have a stack although I have seen newer and older both ways.
    The stack tended to scorch during regens with a 60 series, and I think all Cascadias had DPF.
    Mhyn makes a valid point, the whole apparatus is calibrated to perform with a specific configuration of exhaust plumbing.
  11. Wild Murphy
    942
    779
    I agree. There isn't a real issue for me to convert it. Just wondering if it could be converted and any legit reasons why. Thanks.
