With DD15. There are 2 fuel shutoff valves on the top of transmission. And 1 lline going to Davco . Where do they merge? And is it humanely possible to look at it without tearing whole truck apart
Cascadia's fuel lines
Discussion in 'Freightliner Forum' started by me myself and I, Oct 19, 2019.
There is a tee on top trans.
AModelCat Thanks this.
When did transmissions start using fuel??
Actually i was able to get a good look at it by removing shifter booth. But thats not my problem.
Bubbles in Davco. And losing fuel pressure really fast
you are checking correct spot. check all hoses on top of trans, davco inlet brown plastic tube and valves too . Do you se many bubbles ?
