Cat 15 engine fan won’t turn off parts replaced
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Semidumper, May 12, 2021.
  1. Semidumper
    Semidumper Bobtail Member
    23
    4
    Nov 8, 2019
    I got a 2007 Freightliner Columbia with a cat 15 engine I changed the fan clutch and it was working for about 2 days on and off then it stopped I changed the selenoid also and the high ac pressure switch still nothing fan runs all day
    I will Try to change the low pressure switch also
    any suggestions ?
  3. MM71
    MM71 Heavy Load Member
    760
    991
    Jun 28, 2008
    AZ
    probably a broken wire in the harness .... my guess is ground wire for the high pressure swtich. A shop with Cat ET should be able to tell you what is kicking on your fan.
    Goodysnap Thanks this.
  4. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Most times I run into that is high pressure switch connector. Sounds like you already changed the costly stuff.
  5. rollin coal
    rollin coal Road Train Member
    13,394
    27,212
    Mar 29, 2008
    TN
    Could be the jumper harness to the high pressure a/c switch is not making a good connection. Had this same problem before and a new harness fixed it.
  6. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    Could be your lossing air if the fan not getting air it will run all the time i had the same problem the airline that goes to the fan put your hand an follows it to find air leaks it had to find cause the engine has to be running.
