Cat 3406B getting hot!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Eighterfromdecatur, Jun 29, 2012.
  1. Eighterfromdecatur
    Eighterfromdecatur Bobtail Member
    19
    Decatur TX
    Got a B model in a 87 Pete 379. Guy I bought it from put 4 water pumps on it last summer and I guess didn't fix the problem all 4 times! Bobtail it does fine. Put a empty trailer behind it, runs a constant 190. Pulling a load it'll get hot quick on a small hill and you have to watch her close. Fan runs all the time w the ac kicked on. Radiator was plum full of dirt cleaned that to start w and it helped a little but now it's. over 100 every day so I'm at a stand still. As soon as you hit traffic or stop she will cool right back down to 175-180 real fast. I'm leaning towards having the radiator rodded out. Any suggestions before I pull it?
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    sounds like the whole thing needs to get cooked out and back flushed. Engine block AND radiator. Sounds like a neglected system over the years.
  4. YETI1
    YETI1 Light Load Member
    182
    40
    Jan 1, 2008
    kansas
    My old b same way putting new 5 row radiator to solve the problem just a 1200 .00 problem
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    how hot is it getting? if you go with a new radiator just get a 4 row with the cooling fins at 14 per square inch, it will cool better than a 5 row will. change the thermostats maybe it is sticking. another thing people over look is the cac. if it has a leak it will make the engine work harder.
  6. Eighterfromdecatur
    19
    Decatur TX
    It'll get 200 in the 1st hill I pull loaded. Got to over ride it to keep going I have to back her down to keep going. Even empty she will get hot if u stand in it. I'm fixing to flush the system and go from there.
  7. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    200! thats not hot for a cat. 215 and up then you should get worried. sounds like someone has the screws turned up a little. 200 is perfect running temp for a cat especialy if the outside temp is 100 deg.
  8. Eighterfromdecatur
    19
    Decatur TX
    Yeah it's been 105 here the last week. Guess I can bypass the dummy system and see what it does when u stand in it. I'm going to flush it and run some acid though the radiator today.
  9. Eighterfromdecatur
    19
    Decatur TX
    The pump is turned up 15% over stock and a good mechanic done the work and set the timing so I know it's right.
  10. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    sounds normal for what you got. the only other thing to do is go with 180 stats and a 4 row rad. heck mine runs at 200 deg. on a 100 deg. day grossing over 100,000 lbs. but thats with a 4 row rad and 180 stats. i dont worry until it hits 215 and the fan wont cool it down. then its time to drop a gear and keep the rpm,s up.
  11. 59BROCKWAY
    59BROCKWAY Light Load Member
    168
    68
    Jun 22, 2012
    Northeast
    190 is nothing for her , even 200 is fine for a cat once it goes over 200 the aux fan should kick on by itself , of course you can monitor it too in hot weather and turn it on yourself especially if your in traffic pulling close to gross or over on a hot day. What do you use for coolant? Is it a 50/50 mix ? You don't say how hot she gets ? Maybe trying to flush the system and go from there, also what thermostat is in it , maybe the previous owner put the wrong one back in , that can happen very easily . Hope you make out OK .
