I have a 1986 3406B in a 359 Pete. The jakes are coming on at idle. My mechanic showed me a little black plastic box that screws into the fuel pump. It has two wires going to it. He said if I screw that box into the pump (or back it out a little farther) it will stop the jakes from coming on at idle. So I took it out and played with it. It appars to basically be a limit switch. I noticed when I change the amount that I screw it into the pump the idle speed changes.
What is this box called and how does it work?
Cat 3406B JAke adjustment...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, Jun 22, 2014.
Page 1 of 3
What it does is keep the jakes from coming unless the throttle linkage is at idle position. It works like a reverse light switch. The ball in it makes contact between the pins to complete the circuit. It's designed to not allow the jakes to come on if you are on the throttle. It's normal for the jakes to come on at idle and kill the truck on a mechanical engine. You have to turn the switch off or just rest your foot on the clutch enough to activate that switch if you don't want to turn them off.
maggard359, BeenJammin and rank Thank this. -
Wore out hit it right on head.
wore out, BeenJammin and rank Thank this. -
It's hard to kick the mechanic, most of my age have never worked on the mechanicals. They were retired as we started. Except where I come from we still think a 30 year old rig is pretty late model.
rank Thanks this. -
Get to know your old cat, mine is still painted white I do all my own work, it's just too hard to find a old school mechanic. I did have a clutch put in onetime at a freightliner dealer and after 18 hrs I had to finish the work myself because the mechanics couldn't figure out how to reconnect my shifter air lines. Truck was stuck in deep reduction and that's as high as it would go. In the mechanics defense he probably don't see enough of the motors anymore to remember the troubleshooting.
rank Thanks this. -
I guess technically he wasn't wrong LOL. -
3406"A" block pumps had a jake switch opening that contacted the fuel rack, so if set correctly the rack moved further closed than idle when in deceleration cycle and activated the jake, at idle the rack moved back to a give enough fuel to idle and the jakes didn't stay on, but these were really fussy to set, I don't know if a B/C pump can be set like that or not , never tried,
rank Thanks this. -
rank Thanks this.
Page 1 of 3
