Cat 3406e DPF filter 1998
Discussion in 'Questions From New Drivers' started by MV97, Nov 6, 2020.
  1. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    Hey guys I just want to know more information on if it’s possible to add on a dpf filter for a 1998 truck cat. I live in Washington state so i haven’t heard anything about carb testing and I want to use the truck to go to ports. Also can I just put it on pass the smog test and then disconnect it?
  3. 062
    062 Road Train Member
    6,286
    33,818
    Oct 20, 2013
  4. Idahojoel
    Idahojoel Light Load Member
    63
    48
    Jan 17, 2018
    Phoenix Arizona
    It should pass smog without a filter in Washington unless something’s wrong with it
  5. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    Well to enter port is the only reason we need to pass smog test it needs to be carb compliant
  6. Diesel Dave
    9,283
    29,767
    Jan 20, 2010
    Hesperia, Ca.
    CARB stands for California Air Research Board. It’s California related only. I have no clue what goes on in Washington ports. In California, the DPF for that year is not compliant any longer as of January 1, 2020.
    Brettj3876, 062 and AModelCat Thank this.
  7. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    yea in Washington port they have to be equal to carb standards they said.
  8. Diesel Dave
    9,283
    29,767
    Jan 20, 2010
    Hesperia, Ca.
    Well if that’s so, your wasting your money, your not going to be compliant. You are going to need a 2010 “Engine” which will be 2011 truck.
    062 Thanks this.
  9. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    Crap... thanks did the info
  10. HillbillyDeluxeTruck
    5,940
    30,369
    Mar 3, 2013
    San Antone
    Lets see that law. Have you tried actually going into a port there? Were you stopped, inspected and turned away? If you haven't and weren't and are basing your question off "they said" without any other proof. Id ignore that stuff.
    Diesel Dave, AModelCat and Roberts450 Thank this.
  11. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    I have never heard of anything or anyone but on their site it says it needs to be equal to carb. They give you a device that’s specific to your truck that you need to put your vin in and if it’s before 2007 they need dpf. Sometimes I just want to take my chances and go in. Lol
