Cat 3406e flywheel housing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rydr, Sep 4, 2020.
  1. rydr
    rydr Light Load Member
    123
    92
    Jan 8, 2019
    starter bolt threads are stripped on my 5EK66447 wheel housing, im going to buy a new aftermarket flywheel housing. i know you can not mix c15 and 3406e housings, this engine came out of a 97' 379 and is going in a 08' 389. im assuming I just go with a kenworth/peterbilt compatible housing.
    Flywheel Housings for Aftermarket CAT 3406E Diesel Engine Trucks
    Is there any significance with 'angled motor mounts' or is that normal?
  3. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    I think the motor mounts may be different.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    Why don't you just helic coil the bolt holes ?
  5. rydr
    123
    92
    Jan 8, 2019
    I looked into that, how secure are they? is it considered a permanent fix? I'd hate one day to swap the starter and it strip again. since the engine on out of the truck this is the best time to replace the housing
  6. AModelCat
    161,606
    Heli coils are the way to go. How much labour is involved in removing the transmission and removing the rear structure + put it back together? Probably at least 16-18 hours. Bet you could drop the starter, install the heli coils and have the starter back on in about 2 hours.
    I wouldn't hesitate to use them. I think CAT actually makes a really good thread insert too. Similar to a heli coil but its solid and is locked in with roll pins.
  7. AModelCat
    161,606
    Didn't see where you said the engine's out of the truck.
    If you're hesitant about using heli coils, you could always take it to a machine shop. Very good chance they can weld the holes up, then re-drill and tap them. Probably take them an hour or 2 max. Bet it comes out cheaper than a new housing.
    Opendeckin and stillwurkin Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Did not know about the inserts. We have a Cat running here for two years with those bolts Heli coiled. No one had a coil as long as the hole. We stacked two shorter ones in each hole. No problem.
    stillwurkin, Dino soar and AModelCat Thank this.
  9. AModelCat
    161,606
    Been a loooooong time since I've seen these. I'm fairly certain those tangs get driven into the face after the install, which would lock them in place so they wouldn't spin out with the bolts if you ever had to take them out.
    Flint1, jamespmack and BoxCarKidd Thank this.
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Helicoil in aluminum is better and stronger then new. If engine is out id re seal the rear structure along with rear main and helicoil the starter bolts. Done.
    No need for a new housing.
  11. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    I heli coil one of mine. Easy and better than new. Be careful torquing those bolts, housing is aluminum and if you use anti-seize lube on the threads lower your torque spec accordingly.
    I also put a stud on the top hole, makes removing and replacing the starter a lot easier.
    jamespmack, swaan, stillwurkin and 2 others Thank this.
