Cat 3406e fuel filter base gasket squeezed out while running
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Jun 18, 2017.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    I use a Cat 1r 749 on the spin on base it popped the base gasket out while idling approx 60psi, this is with a new bypass check valve. I have never had this happen I install the filter with same "torque" as I always have using a band wrench. Is there a specific torque value for this filter? It be a real pisser if this happened while driving.
  3. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Hand-tight served me well for over 20 years....no need for a filter wrench unless it's removing it....are you sure the seal from the old filter didn't stick to the sealing surface?
    Oxbow and gafred99 Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,433
    6,469
    Aug 26, 2014
    Hand tight should be enough. Did it have a different brand filter on it with an O-ring in the middle and it's still there? Once upon a time I worked at a company shop that bought filters by the case. We received a whole case of filters with the wrong threaded ends in them, no where close. I would suspect something like that. Center of the filter bottoming or improper threads?
  5. gafred99
    155
    12
    May 28, 2009
    Tignall
    Originally it had no filter there, then I replaced the short cap with CAT branded filters and made sure the seal always came off when switching it.
    tony97905 and Oxbow Thank this.
