cat 3406e jakes quit working and so did
Discussion in 'Trucks [ Eighteen Wheelers ]' started by WallyGator, Apr 30, 2009.
  1. WallyGator
    WallyGator Medium Load Member
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    the brake pedal cutoff switch.wont work with cruise. tried to get power at switch no luck..freightliner or cat dont know where the relay would be or any type of fuse.:biggrin_25513:wiring diagram in truck dosent show it.:biggrin_25513:.any help would be greatley appreciated Walt. PS it's a 1995 3406e-5ek motor....
  3. Jas
    Jas Medium Load Member
    Hey Walt,
    All Aus trucks work as follows, I would assume yours is the same.
    The brake switch gets power from pin 14 on the OEM plug on the ecm and returns to the OEM plug at pin 29 (sensor return). This is a simple loop, wire from pin 14 goes to one side of the switch, wire from pin 29 to the other side of the switch. No relays or fuses. BTW pin 29 is a return for a lot of other sensors so you have to tee any new wires into it rather than cut it out. There will be two switchs, make sure your checking the right one, one is for the ECM, the other is for your brake lights.
    Jas.
    WallyGator Thanks this.
  4. Six8888
    Six8888 Bobtail Member
    16
    Fontana, Ca
    so what quit working? or is your problem that the jakes won't cut off? don't really understand the question
  5. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    when you turn the switch on nothing happens. it has two switches one for 2 cyl and one for 4cyl.the brake pedal wont shut off the cruise control unless you step on it as hard as you can.it dosent have a switch at the brake pedal. thanks for the replys so far. Walt
  6. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
    if u need to press the brake pedal hard for that to happen check if the brake switch is ok maybe it is sticking
  7. Jas
    The switches will probably be air pressure switches, either on or near the treadal valve or on the fire wall in the engine bay.
  8. beeper
    beeper Bobtail Member
    9
    Jun 3, 2011
    nettie,wv
    do u got power on the clutch switch??
