Cat 3406E Question! MPG Poor at 3.5-4 mpg.
Discussion in 'Ask An Owner Operator' started by rslivelyjr, Jun 18, 2024.
  1. rslivelyjr
    rslivelyjr Bobtail Member
    39
    10
    Mar 14, 2023
    I have a Cat 3406E. Year 1994 . The motor is sitting in a 379 Pete. Transmission is a 15 Speed with 3.73 rears. Tires are 24.5 tall . The motor has a 550HP and 1850 Torque tune, new fuel pump , filters air and fuel . We are getting 3.5-4.0 MPG. The turbo side of things as follows , we tried running with the waste gate and without same results . Boost with the waste gate is around 30 without waste gate is around 40-42. Also truck hauls around 80-88k per load .
    Question is : We heard someone say adjust the waste gate for lower boost to get better MPG . Is this true ? What can we do to get any better numbers .more boost less boost? Thanks guys
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,409
    6,653
    Oct 22, 2016
    North Dakota, Eh?
    How fast you drive? Terrain? Stop and go?
    Deere hunter Thanks this.
  4. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    stock turbo?
    for fuel mileage to go up keep boost pressure down.
    Deere hunter and Sons Hero Thank this.
  5. rslivelyjr
    39
    10
    Mar 14, 2023
    Speedlimit
  6. rslivelyjr
    39
    10
    Mar 14, 2023
    So could adjust waste gate for lower boost pressure?
  7. Sons Hero
    Sons Hero Road Train Member
    2,402
    23,936
    Jan 8, 2021
    Indiana
    Higher RPM, less lugging. Drivers foot can be a big part of it too. And if you run in the mountains doing a lot of stop and start. You stay local? That will hurt it too if you don’t just wind it up and hold it on the highway.
    Crude Truckin' and Deere hunter Thank this.
  8. rslivelyjr
    39
    10
    Mar 14, 2023
    So I’m local , I run from one mill back to reload 75 miles apart . Back and forth , some hills yes but mostly 4 lane hwy, 65 limit 90% of the 75 miles . So with that Cat motor keep it in high rpm’s? Don’t let it lug at all? Because I’ve tried that before and no difference, but I’ll try again
  9. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    NO. lower your boost pressure with your right foot. Drive with your boost gauge, try and keep it down. usually with higher PRMs and no lugging
    cke, Crude Truckin' and Sons Hero Thank this.
  10. rslivelyjr
    39
    10
    Mar 14, 2023
    But I can run high rpms and boost still at 30 that 15 speed is spread out
  11. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    take your foot out of it
    cke Thanks this.
