Cat 3406E swap, what do I need to know?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by McMahons Trucking, Oct 17, 2018.
  1. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    My Cat bit the bullet yesterday. I know of a wrecked Freightliner with the same engine only it has an 18 speed. I have a 10. Can i swap this engine into a Pete? I realize I'll have to swap mounts etc... Anything other than that?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If it's the same engine then it will be a direct bolt in. Not to hard to figure out.
    Both E models assuming?
    Oxbow, AModelCat and SAR Thank this.
  4. McMahons Trucking
    274
    119
    Jul 4, 2018
    Yes both E models just different mounts I'm assuming.
  5. 062
    062 Road Train Member
    6,275
    33,779
    Oct 20, 2013
    Oil pan may be different about only thing.
    Oxbow, mslashbar and swaan Thank this.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yes so just re@re mounts from engine to engine if not the same. Oil pan if front or rear sump. Accessorys like alt and A/c need swapped over as well.
    Good time to do a clutch and new engine mounts as well. Maybe rear main seal if old or leaking?
    Oxbow, SAR and 062 Thank this.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Get the whole thing resealed while you have it out, save some headaches later down the road.
  8. jake744
    jake744 Light Load Member
    126
    138
    Dec 27, 2017
    I think paccar uses a different engine bell housing. Paccar has a different degree of slope where mounts bolt on if I remember correctly.
  9. Peterbiltt
    Peterbiltt Light Load Member
    236
    88
    Aug 21, 2014
    Ontario Canada
    swap that 18 in with it.
    Oxbow, roshea, AModelCat and 1 other person Thank this.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    That too.
    Oxbow and spsauerland Thank this.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Exhaust manifolds may be different/ low mount vs mid mount. They both same HP family?
    Oxbow and SAR Thank this.
