Cat 40 pin ecm voltage to fire
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kiah, Jan 19, 2023.
  1. Kiah
    Kiah Bobtail Member
    12
    9
    Jan 17, 2023
    Struggling to find an answer anywhere, I have a c12 in a 1997 ford aeromax. How many volts does this ecm need when cranking to fire? I have 12.4 on pin 4 and 6 with key on, but am down to 8.9 on those pins when cranking. Truck one day decided to crank and not start, speeds up a bit on ether, has 55psi for fuel, fuses and relays are good. Thanks!
  3. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    I wanted to bump this to the top because I'm interested in the answer.
    Kiah Thanks this.
  4. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    just spent some time on Cat SIS and this is all I could really come up with for published info from them on the topic.
    Cat doesn't list a minimum voltage where it stops working under, however they do state prolonged use at under 9V can cause damage to the ECM due to the increased current draw(which makes heat) it requires at that low of voltage to run things like the injectors.
    Kiah and Luwi67 Thank this.
  5. Kiah
    Kiah Bobtail Member
    12
    9
    Jan 17, 2023
    Thank you very much for your reply! I found that the previous owner of this truck had spliced into the ECM wire from the batteries(for underglow lights lol) causing it to rot through completely and also rub and rot through the main heavy battery cable 3/4 of the way. So id imagine this ECM may have been damaged from that then as you mentioned with under 9voltsfor a long time. Fixed all the wiring and put on a reman ecm with still no start. I have a tech coming with Cat ET next week to look into it further and will post what the fix is hopefully. good chance this new ECM may also be a dud. Thanks!
    bjytech, Crude Truckin' and Oxbow Thank this.
  6. Kiah
    Kiah Bobtail Member
    12
    9
    Jan 17, 2023
    Just to update what the fix was, replaced a lot of old damaged wiring with no change, also tried a reman ECM but had the same crank no start problem, both ECMS tested out fine, changed the cam position sensor as finally had it checked with cat ET and it showed 0 rpm while cranking. Truck instantly started up and runs with new cam sensor. Been quite the mess around but was also a good opportunity to fix up bad wiring along with better grounds and new fuel filters, primer pump etc.
    bjytech Thanks this.
