Cat 5EK fuel pressure?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TA63, Jan 21, 2011.
  1. TA63
    TA63 Bobtail Member
    48
    Oct 28, 2010
    What should a 1994 Cat 5EK engine run for fuel pressure? Also, this truck does not have a pressure gauge. Is there a port somewhere i can test the fuel pressure?
  3. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Mine runs a tad over 75 but bounces around a lot... I believe there is a fuel port on the filter housing...
  4. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    port is on the filter housing, its a cap you remove it and screw in your gauge, I generally shim pump to achieve 110 to 115 psi at 1800 rpm.
  5. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    I think thats a 3/8 boss O-ring fitting
  6. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    The older 5EK's use a larger pump with more volume compared to the newer pumps. Most of them run at 65-75 psi while cruising down the road. Be careful playing with these pumps, you can very easily raise pressure over 150-200psi before you know it. If you install the wrong check valve, you can raise pressure dramatically also
  7. doublew
    doublew Light Load Member
    68
    7
    Oct 17, 2010
    Kansas
    i have a 5ek and mine runs right at a 100 to 95 psi on a fresh filter and i will change it at when it drops to around 60psi
  8. Rig Wrench
    Rig Wrench Medium Load Member
    398
    66
    Dec 24, 2010
    northeast
    Would there be an improvement then running a 5EK pump on a newer engine if they move more volume(and shimmed it for the correct pressure)?
