cat 6nz rebuild question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigstank, Dec 11, 2013.
  1. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    I spun a rod bearing last week and I'm doing an inframe. What I wanna know is, should I replace the pistons or use the same ones with new liners, I gotta put a new crank in and head but I don't need everything the cat platinum kits gives thanks guys.....
  3. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Oh and the piston didn't hit the head, I'm exchanging the head out cause I had a crack in it for a year so might as well
  4. Cat sdp
    Cat sdp . .
    20,969
    73,067
    Apr 8, 2012
    Orion's Belt
    Is getting a warrantee on the rebuild a factor for you ? I though they were " giving" a 3 year one with the platinum kit....?
  5. bigstank
    87
    19
    Mar 4, 2013
    missouri
    No! I'm doing it myself, I got a PDI tune, turbo, manifold and 800hp cam. I don't want cat to ruin my set up, I got 750,000 outta this rebuild I did lastime with the cat platinum kit
    Cat sdp Thanks this.
  6. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Spinning the rod bearing was my fault, I got on her a little too hard at the truck pulls, but hey on the bright side I did WIN full pull in my class LOL
  7. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    First of all as a truck mechanic I am not sure how your going to replace crank with engine inframe. I'm not saying its not possible but you will have the trans out the heads and front cover off to pull the rest of the engine is really not much more work. About the piston replacement I would highly advise new pistons with new liners not sure about cat but volvo cyl kits come with liner,piston, and rods all assembled.
  8. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Ima drop the tranny and lift the engine up to get it, I gotta do the clutch while its down
  9. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Why wouldn't you? In that deep, seems kind of foolish to me to put used anything back in especially if you are planning on puling with it again. In my opinion 750,000 miles on a part time pulling truck is pretty good. I don't think I would tempt fate. I'm just sayin...
    bigstank Thanks this.
