CAT 6NZ uprate question, serial number in picture
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dieselfuelonly, Oct 5, 2017.
  1. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Any CAT guys here that can run my serial number? Just wondering what my 6NZ can be uprated to with a factory flash. Driveline is rated for 1850 ft/lbs and is supposedly set at 475/1850 now. Dyno'd at 402 HP at the wheels when I bought it, 24.5 rubber.
    Also, I'm confused - it shows ADV 475 HP and MAX 445 HP. What does this mean? ADV = Advertised horsepower?, but it's above MAX? Just curious.
    THANKS
    SER. NO. 6NZ87859
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I never ran your serial # but I'm almost positive all the 6nz series you can up rate to 550/1850 without a hard parts change. It's just a simple reflash. Especially because yours is a 475 now.
    There not like some the early low HP E models that required hard parts to get to 550.
    dieselfuelonly, Oxbow and SAR Thank this.
  4. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    This is from CAT SIS
    C-15 TRUCK ENGINE
    Engine Serial Number - 6NZ87859 (Build Date - 16/09/2002, Test Date - 16/09/2002, Ship Date - 19/09/2002)
    S/N 6NZ30993-90822
    354 BRAKE KW (475 BHP) AT 2100 RPM. PACCAR, JAKE BRAKE
    dieselfuelonly, Oxbow and cke Thank this.
  5. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    All 6NZ can be uprated to 550/1850.
    As for the advertised HP and max HP being different I'm not 100% sure on the reason they do it but I know many times it has to do with a "smart torque" power rating where it limits output power based on engine load and other parameters.
    dieselfuelonly and Oxbow Thank this.
  6. dieselfuelonly
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Thanks guys, appreciate it.
  7. 6NZoom
    6NZoom Bobtail Member
    39
    13
    Feb 4, 2019
    British Columbia
    For what it's worth, a Peterbilt mechanic friend of mine told me that they (Peterbilt), would flash my C15 475/1650 torque engine to 550 HP, but not uprate the torque as long as I retained my low torque 10 speed tranny.
    Now that I've upgraded to an 1850 torque 18 speed, they'd have no problem flashing the whole program.
  8. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    And you won't notice a bit of difference
  9. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Heard the story so many time of guys flashing from 475 to 550 and noticing little to no difference. A dealer reflash is worthless. Need a GOOD tuner to make a real difference. A cat dealer is limited to using the latest cat file. Latest does not equal greatest
  10. 6NZoom
    39
    13
    Feb 4, 2019
    British Columbia
    Thanks Lester. You're absolutely right. I'm still on my factory 475HP file. No need to pay a bunch of money for little to no results.
