Cat 6TS 3406E reman head vs new head
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hammerstrap, Dec 20, 2014.
  1. hammerstrap
    hammerstrap Bobtail Member
    48
    23
    Oct 23, 2012
    The head gasket on my second Aeromax let go. We pulled it down to find it let go in the relief cut between 5 and 6. I took the head to same machine shop that Michigan Cat uses. They called and it didn't pass magna flux inspection. So the big question is what is the better way to go? Reman from cat or buy the new head and have my valve train put in that? Can I even get a head without the relief cut? Expense isn't the issue.
  3. Truck engine machinist
    Truck engine machinist Light Load Member
    195
    185
    Dec 2, 2011
    USA
    Cat reman heads are all new castings now.
    hammerstrap Thanks this.
  4. CaboverKid
    CaboverKid Light Load Member
    138
    31
    Dec 20, 2014
    I have a 6TS and with 200K on it I am doing injector cups. Its a reman aftermarket head. Lucky for me it wasnt grooved out where the cup O-rings were, but thats very possible on an aftermarket cat head...
  5. hammerstrap
    48
    23
    Oct 23, 2012
    I was leaning toward a new casting so I wouldn't have to worry about the deck being cut, but if they are using all new castings at this point I should be safe then.
  6. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    A new cylinder head is not going to cure a low liner. Definitely check your liner protrusion and make sure they are all up to spec, or you'll be going back and re-doing it before too long.
