The way these vva's operate is simple but how does ecm determen what cylinder is not responding. I just learned that when the ecm activates a cylinder to operate and that cylinder doesn't the ecm knows because there is no spike in oil pressure that the vva oil pressure sensor is looking for. I thought this would be a good thread for all of us to teach and learn about cats vva's.
cat acert vva operation
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gear head, Dec 26, 2012.
From the way i understand (which can be horribly incorrect), the ECM knows which actuator isn't responding by looking for an oil pressure spike after the command for the actuator to activate. For example, the ECM commands the #4 actuator. If the VVA oil pressure sensor then detects an oil pressure spike in the VVA oil galley immediately after, all is well. However, if the VVA oil pressure sensor doesn't detect a pressure spike, or a spike that is too small or too delayed, it will throw a fault code corresponding to cylinder # 4.
Yes you are correct! I just learned this. There is no documintation on this. The only documintation is in cat manual on operation. There use and how they work not how ecm looks at it. The vva solnoid is opened for oil to get to vvas. The oil is always there for jakes. I also learned when they first came out that they only operate under a load. Thats why if a vva is unhooked or bad it may take 8 hours for ecm to figure it out. I have talked to cat tech for east coast and he said they are supposed to let more air into cylinders under load and from his resurch thats why they added thr twin turbo system. He also said that it's based from miller cycle but cat willn't say this or take claim to that.
There's a very well written and informative thread around here somewhere in which Mr. Haney explains the how and why of the VVA's and tcompound turbos. Excellent reading; I recommend it to anyone who would like to try to understand an ACERT.
