cat c-15 diagnostic code 72
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rayray632, Nov 15, 2010.
  1. Rayray632
    Rayray632 Bobtail Member
    5
    El Paso TX
    Can anyone answer what might cause this code 72. The code is 1 and 2 cylindr fault code. It only happens for a few seconds then the truck runs fine for 500 miles then acts up again for a few sec.
  3. mysticguido
    mysticguido Light Load Member
    235
    47
    Sep 20, 2010
    Wharton, TX
    Code 72 are random misfire in cylinders 1&2. Possibly caused my many different things.
    Ran fuel cleaner, still misfiring,Check glow plugs, Exhaust, Header,underdrive pulleys,grounding wires.
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    You have a common wire that is broken between the ECM and injectors 1 & 2. When you lose current at this wire cylinders 1 & 2 will misfire until continuity is restored. It could be the plug at the wiring harness connection at the valve cover, start wiggling wires with the engine running until you make it misfire..........then you know you're close to it. You should be able to isolate it to which wire it is and where with wiggling each wire independently..........it should be a white wire
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Mr. Haney is right! Imternal damage of C15 ECM are very rare. So rewire and n'joy!
  6. Rayray632
    5
    El Paso TX
    Thanks guys for your advice, its very well appreciated. Now I will know what to look for...one other thing. When it does this it loses power like if I have a clogged fuel filter. Could this possibly also cause this to happen?
  7. Diesel Dave
    8,620
    24,211
    Jan 20, 2010
    Hesperia, Ca.
    I had the same problem when I brought the rpms above 1700 on a pull. I had to replace the hardness INSIDE the valve covers. Can't remember if it cost around 350.00, for part only. And had to call several dealers to find it.
  8. Rayray632
    5
    El Paso TX
    I've replaced that harness...its two of them. They run around 165.00 a piece, I replaced both of them. I was getting a code 95 and they do a repair kit on the harness. I decided to replace it. This was a few agos.
  9. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    That is an old design turbo with the S400 frame. It has a small shaft and bearings and isn't woth the time to install. I prefer the newer S410 frame turbos with the Extended Tip Technology compressor wheels.
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I had broken wires inside connectors. try to pull common wire!
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    technitions do not like open valve covers... threre are similar problems with Volvo D13 and Scania PDE engines....
