CAT C12 OIL FILTERS
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MIg25, Jun 5, 2020.
  1. MIg25
    MIg25 Light Load Member
    73
    20
    Apr 10, 2020
    Fort Lauderdale - Florida
    Hello truckers and family,
    Would someone be able to help me figure this out? Why my Freightliner FL 112 2003 Caterpillar C12 engine has only one oil filter?
    Why is the secondary disabled, it appears to me it has been factory disabled.
    Any input would be greatly appreciated.
    Thank you.
  3. AModelCat
    158,336
    That's probably the CAT arrangement that Freightliner selected for use in that truck model.
    CAT breaks their engine models into different prefixes, then within those prefixes, there are different arrangements.
  4. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Second filter is ussually a bypass in case the main filters plugs with debris. Maybe an option on this engine? Some smarter CAT fellers will share more.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,466
    6,504
    Aug 26, 2014
    Some of the 3176,s that were here had two filters side by side like that. The primary is a 1R1808, LFP4005 or 57792. The secondary filter is a bypass 1W8845, 51749 or LF777.
    You can look up the microns of each. All of the oil that runs through engine is filtered by the primary unless a bypass opens. The secondary is a very fine filter, normally only has two inlet ports into it, and returns oil back to the pan. Only a small amount of the oil that runs through the pump goes through it.
    The 777 replaced the big LF750B Luberfiner bypass filter. When the new trucks came out with those oil change intervals went from 8,000 to 16,000 miles.
    You would probably need a nipple in order to install a second filter on you truck. I have never done that.
    Things like that happen for different reasons. I have a Cummins with the 777 blocked off and a Spinner II mounted on the frame?
    spsauerland Thanks this.
