Cat C13 blowing oil cap off
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Guntoter, Dec 22, 2022.
  1. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    I can't find anything in the search about checking/changing the breather on a 2006 C13. Im assuming it started blowing the filler cap off because the breather is plugged or broken. I have very little (if any) blow-by coming from the tube under the engine, but a small amount coming from the filler neck. I replaced the cap with a brand new one and it blew off within a few miles. No water/oil contamination in the radiator or oil pan, no smoke from the stacks. My thought is maybe the PCV, I read that there is a tin plate riveted inside the box that the tube drops out of (driver side front of the engine), if this plate is detached, the blow-by gets trapped.
    Any ideas, am I on the right path or could it be something else?
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    Blow by tub is probably clogged and under boost it blows cap off
    W923 and Guntoter Thank this.
  4. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Ooops... Habit I guess, it's a C13.
  5. ultra truck
    ultra truck Bobtail Member
    17
    7
    Oct 21, 2020
    Deland Fl.
    A c13 had a filter and it should b a screen in the drivers side neer front of valve cover. If a accert c13 it should be about the same place but it's a filter in a round can style tank by the top of the blow by tube by valve cover.
    W923 Thanks this.
  6. IH9300SBA
    IH9300SBA Road Train Member
    2,373
    23,144
    Feb 26, 2021
    I remember a Service Bulletin where we had to tap the oil fill tube and put a new oil fill cap on, and I believe it was the expandable rubber plug but don't recall exactly. Seems the original was a plastic cap that locked on to two nubs and wouldn't hold.
    Oxbow Thanks this.
  7. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I ordered a new fill tube and cap for a C15 this week. The new one was smaller than the old one. I remember something in the past about tapping the fill tubes as well.
    Oxbow and IH9300SBA Thank this.
  8. Lowboy456
    Lowboy456 Light Load Member
    278
    128
    Mar 14, 2017
    My C13 blew the filler cap off yesterday and I lost 5 gallons of oil before realizing it. Luckily I stopped for a bathroom brake and saw oil all over my left battery box and dripping off the fenders.
    Oxbow Thanks this.
