Cat c13 engine 08+
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Jan 19, 2013.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    Hi ,i have a question i drive a columbia 0 7with a c13 (kcb),iam thinking to buy this year a other truck with a c13 engine with dpf,is the c13 with dpf a good engine or not ,iam little confused what engine i buy in my next truck,iam betwin cat and detroit.thanks for you answers
  3. Cat sdp
    Cat sdp . .
    21,204
    75,309
    Apr 8, 2012
    Orion's Belt
    All dpf only engines are crap and the cats are the worst of the lot . Save your money and get an 010 spec engine. Or keep what you have now. You will be much better off.
    But some say I whine to much ........ LOL
  4. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    you talking about 011 modell with 010 engine.when yes i think the detroit dd is the best ,i like to buy a truck to go in the future to cali
  5. Cat sdp
    Cat sdp . .
    21,204
    75,309
    Apr 8, 2012
    Orion's Belt
    Yes..........
    gerardo1961 Thanks this.
  6. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Do not buy that motor. I have a c15 cat with DPF and it has a heck of a lot of headaches. My mileage when I bought it was 4.0 mpg and NO POWER. I had a full rebuild right under warranty at 499,000 mi all under cat warranty, they had to put a new CAC, new DPF, totally rebuild the engine. I only had to pay for new cylinder packs. I am now up to 5.8 mpg steady on winter Canadian fuel (only doing short runs for now), I have added fuel temp wire, MB wheel bearings in 5 axles, and a trailer skirt, pulling reefer. I consider myself very lucky with this engine. For now, the aftermarket DPF cat put on isn't giving me lots of grief like the old one did. However, when I run it hard in mountains or above 1500 rpm for maybe an hour, in the 75 mph limit states, the DPF throws check engine code which I now know means I have to park it and do manual regen. Keep it at 65 (1400 rpm, I have 3.55 on 24" lo-pro, 18 with .73 final) and it works fine. I would NOT buy another dpf-only motor. If I had to buy another truck today and it had to be compliant for cali, it would be something with the 2012+ detroit that takes def. I should also add that I would not buy any motor with the VGT either. Apparently they last about 1 year then break. Plus, all the new maxxforce, and paccar motors, I don't have faith in them either. Volvo or mack just aren't in my vocabulary.
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    If you won't buy any engine with a VGTurbocharger than you won't be buying any truck. Detroit, Cummins, Volvo, the whole lot of them, have a VGT on them now
    The DPF Cat engines can be made to run with a DPF Delete
  8. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Get the Detroit. The 07-10 EGR only Series 60's were far superior in fuel mileage and reliability than the 2006 and older EGR models.
  9. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Didn't know all of them had the VGT. I thought the Detroit's didn't have them, my mistake.
    The only thing holding me back from totally deleting my DPF system is my plan to run some cali in a few months while the produce is rolling. If I find I will be doing better running other areas of the country it will be off of there.
  10. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    Dont know much about DPF delete. How would someone know if its deleted?
    90kw Thanks this.
  11. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Well for starters the black tips of your exhaust will give them reason to take a closer look. I have heard but never confirmed that sometimes they have a camera they put down the exhaust to look for the core inside the dpf. Also they do the snap testing to look for black smoke. The thing is if you get caught what do you do when they tell you you are going directly to the repair shop and it will be several thousand to "fix" it, or else you are impounded? I've thought about having it deleted and drilling down to leave 1/2" so it all looks cool, but not sure if that will eventually have the same problems, clogging the exhaust shut pretty much. Oh yea, and some states are plugging into ECM's now. Not sure what exactly they are looking for there.
    rickybobby Thanks this.
