CAT C15 1 piece oil pan gasket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by C15Mike, Apr 30, 2018.
  1. C15Mike
    C15Mike Light Load Member
    54
    27
    Sep 15, 2016
    I have a leaking oil pan gasket on my MBN that I want to replace. I see that there is a couple aftermarket 1 piece gaskets instead of the puzzle gasket that CAT has. Does anyone have any experience with these and if so which 1 piece did you go with or is the CAT gasket better? Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,717
    9,024
    Jul 12, 2017
    Go with the Cat 1 piece gasket IMO. High grade rtv sealer applied at the front and rear housing seams. I hate that puzzle piece gasket with the passion. High tack is your best friend with that one though if you go with it.
    black_dog106, petefan4000 and Oxbow Thank this.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Most ones I have seen on a C-15 are one piece pan seal/gasket. I think BS ones used multi piece gaskets. Depends on stiffner plate. What is your ESN and we can look it up.
    black_dog106 Thanks this.
  5. C15Mike
    54
    27
    Sep 15, 2016
    I didnt know that, I thought they were all the puzzle gaskets. My serial is mbn10942. Thanks!
  6. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Yours has single piece isolator gasket P/N 168-5248.
  7. C15Mike
    54
    27
    Sep 15, 2016
  8. Cjlloyd81
    Cjlloyd81 Bobtail Member
    Any idea what gasket for MXS93650? Thanks :)
  9. C15Mike
    54
    27
    Sep 15, 2016
    Pretty much the same block as a single turbo C15 so same gasket as mentioned above.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    The "puzzle gasket was for the e- models. C-15 uses a one pc "rubber" gasket and bolt isolators. Make sure it isn't just one of the isolators leaking instead of the pan gasket.
    Oxbow and Diesel Dave Thank this.
  11. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    I used an IPD pan gasket that was suggested by spsauerland and it was easy to install and is not leaking.
    Oxbow Thanks this.
