Cat C15 Acert Blow by with video
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dreyvn, May 27, 2019.
  1. Dreyvn
    Dreyvn Bobtail Member
    36
    11
    Jul 27, 2018
    This is on my 2006 MXS C15. Approx 575,000 miles on platinum overhaul. Is this considered normal blow by on acerts? Or should I be concerned? Thanks.
    jamespmack Thanks this.
  3. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    Try taken it to a different cat shop and see what they tell you I have alot more blowby then that but my has 1 million on it and never been opening up mind is due for a overhaul everyone saying.
  4. DmitriyKW
    DmitriyKW Bobtail Member
    47
    65
    Feb 10, 2015
    Sacto, CA
    So what did you ended up doing? Is it a lot of blow by? I have Same engine with almost 700K original miles and it has a lot less blow by. What’s your oil pressure when driving at normal conditions and at the Idle?
  5. Shawn19
    117
    34
    Apr 20, 2019
    You sure that all it has on the overhaul and not more
  6. sloshed
    sloshed Light Load Member
    56
    11
    Aug 5, 2013
    If you want piece of mind on blowby you can take it to a CAT shop and have them do a Dyno on it. The Dyno test will include a compression test and from my understanding if your blowby is less than double the engines HP rating then you are good. Last time I did this it was around $375
  7. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    that's more than nominal, but not what I would class excessive.
    I would say its either glazed, carbon packed or the rings are soft and wont seal well without boost.
    does it use oil?
  8. Shawn19
    117
    34
    Apr 20, 2019
    I agree it look like it to me.
  9. Polito82
    Polito82 Bobtail Member
    4
    I have the same problem
    2006 Peterbilt 387 with Cat C15 Acert MXS.
    This truck was sitting over 2 yr only run engine a few times last year and change oil last august,from this date was run 1 time (1o 2 hr) every week . Just I change Oil pressure sensor it is front right side of engine and check engine was turn off . When start idle 70psi cold later run at 1400 rpm/ 200f /60 psi. I leave engine run only idle the oil pressure down to 25 and 30 psi later go up to 30psi . Is running normal o have something wrong ...
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    @Superhauler
