Cat c15 acert bxs to 3406e
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ruben01, Mar 18, 2022.
Unless it’s blown up I’d tune and delete the BXS before I went changing it.Shawn2130 Thanks this.
We have both a BXS and 3406E trucks. I drove both.
I drive the BXS. Nothing wrong with these engines. The 3406E is not much different other than no IVA and only a single turbo.kranky1 Thanks this. -
Yes you can !
Locked up I want to know if its a actual plug and play if I dont have to mess with the ecm harness
I want to know if it p
its locked up and wanted to know if u can put a 3406e without messing with the ecm harness -
Is it plug and play or u have to mess with the ecm harness to make it work?
Harness issue. You would have a 70 pin truck with a 40 pin engine in it. The harnesses are around for that swap though.
Kranky1 is right.
The 2WS is a 70 pin and still labeled 3406E. The 5DS 15.8 liter was also labeled 3406E. My point is yes a 3406E is most likely a 40 pin and will require simple modification but without a serial number who really knows. They are not all the same as people think
Oxbow, Roger McG, bjytech and 1 other person Thank this.
