Cat C15 coolant in intake of the head, Oil is clean? Recent in frame.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by R. Grief, Aug 23, 2021.
  1. R. Grief
    R. Grief Bobtail Member
    Need help, 06 cat C15, in frame done 80k ago. No issues until coolant started getting pushed out of coolant tank vent hose,under heavy load. Boost gauge reads 60 ish. Replaced, coolant tank, injector cups, had head pressure tested. Just found coolant in intake of head. No coolant in cac. Pre cooler dry, EGR cooler dry . Oil is clean.
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    I dont think this could be anything except a pre-cooler. If you did have compression leaking past a fire ring/ head gasket, it is unlikely the result would get coolant all the way around to the intake. If it did leak coolant internal it would leak in cylinder and cause hydolock or drain to the crankcase.
    Under hard pull the boost pressure exceeds cooling system pressure on the precooler forcing air in the coolant. When the boost is below coolant pressure or when setting, it can leak coolant. I get you said it was dry.....I would pop the pipe off hot and leave cooling system pressure on overnight and see if anything shows up. My vote is the pre- cooler.
    Not a strong Cat guy, but maybe others will voice an opinion.
    CAT does not use EGR.
    Please share ESN so we all know the exact engine you have.
    Thanks
    Oxbow, A5¢, BoxCarKidd and 2 others Thank this.
  4. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    I'm definitely not an expert on anything but a cat with coolant in the intake couldn't be anything but the pre-cooler, could it?
    Oxbow, BoxCarKidd and Rideandrepair Thank this.
  5. AModelCat
    161,302
    There shouldn't be EGR on that engine. That didn't come out until a few years later with the SDP I think.
    Oxbow and Rideandrepair Thank this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Coolant residue or actual coolant? Could be cracked head.
    Oxbow and A5¢ Thank this.
