Long story short.
Hit a deer, coolant leak from a hole on the bottom of the rad. Managed to drive it to a truck stop as the last of the coolant was leaving the reservoir.
All the coolant leaked out through the rad, I ended up patching the hole with JB and refilled with distilled water, no water was leaking I thought I was in good shape.
Ran truck for about 10 minutes and shut it down. waited about 5 hours to cool. Topped coolant off again as I assumed it was getting air out of the block or something.
Noticed that the res was empty today, poured in about 2 gallons to bring it up to min line.
Now I have coolant leaking from the bottom of the transmission. Looks like its coming from inside the transmission?
I have the bunk cores and interior core valves turned off, they were off during the deer strike.
Now the leak is pretty fast, I need to get it 370 miles to my mechanic that was going to replace the rad. But I don't think I can drive it like this?
Cat C15 + eaton 13, coolant leaking from transmission?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Joeziah, May 29, 2022.
AModelCat Thanks this.
I suspect if I pulled that plug it would belch coolant though, I'm thinking the impact of the deer must have caused the tranny oil cooler to fail. I was seeing some nasty oil like stuff but I thought it was just the CAT ELC mixing with water. Now I suspect it was the transmission oil. Deer was centered and went under the truck so maybe it did more damage than I thought.
Guess I'm not going to get away without having it towed. I have zero experience with transmission coolers, much less one that appears to be internal. -
Roger McG Thanks this.
Update, tranny full of coolant, everything points to a breached oil cooler and there must be a breather that it started leaking out of.
If the transmission oil cooler has coolant lines in and out, and transmission oil in and out. the transmission cooler is junk filling your transmission with coolant. Replace that cooler with a heat exchanger cooler
The oil to coolant ones do have an advantage though if you're up in the north where it routinely hits 30 below or colder. Keeps the oil flowing easier.
Roger McG Thanks this. -
