Cat c15 mbn knock
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by joey8686, Apr 7, 2018.
  1. joey8686
    joey8686 Light Load Member
    131
    154
    Jul 1, 2014
    Hello everyone looking for help with my 04 Pete 379 with c15 mbn I have a weird knock around cylinder 6. At light throttle n low rpms it knocks/rattles and at idle. If I give it lots of throttle or pull a load I don’t hear it unless I’m at light throttle low rpms. No smoke really just a bit of black when up lshifting. Sometimes it seems like it’s missing then next minute seems ok n smooth at idle,looking for a little help before I bite the bullet n take to the shop, also the noise sounds like it’s in the combustion chamber area and I took valve cover off and nothing is broken or loose up their
  3. AModelCat
    161,487
    Sounds like an injector starting to go or maybe an issue with the wiring harness and pass-through connectors. Have you tried wiggling the injector wiring harness with it idling? If you can make idle rough and then smooth out when you wiggle the harness that'll be your issue.
  4. joey8686
    131
    154
    Jul 1, 2014
    I haven’t tried that, but I will now thanks
  5. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    don't grab the steel nuts under the rocker cover to the injector solenoid. there 120Volts in that circut
    joey8686 Thanks this.
  6. joey8686
    131
    154
    Jul 1, 2014
    Update: I took off valve cover and unplugged #6 injector and the knock goes away, does that most likely mean it’s the injector? Can I swap another injector into that hole say from cylinder 1 to see if the noise moves to that cylinder?
  7. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    Yes you can swap to see If it follows injector.
  8. Diesel Dave
    9,280
    29,740
    Jan 20, 2010
    Hesperia, Ca.
    That’s what had done when I thought I had an injector issue. The O-rings should be changed each time you pull an injector out.
