CAT c15 Metal shavings in fuel filter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, May 18, 2020.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Primary and secondary have metal shavings in them.
  3. AModelCat
    158,342
    Well sounds like you've got a sick Kitty.
    MBN right?
    Only thing I can think of off hand would be the fuel pump is going out. Unless you did pick up some bad fuel when you were dealing with that discoloration in 1 tank. I guess its possible an injector is coming apart but I would think you'd be seeing some carnage in the top end if that's the case.
    What's fuel pressure like?
    anthonyar4 Thanks this.
  4. anthonyar4
    431
    92
    Jun 8, 2019
    Gonna have them. Check that. But I noticed my dash is having issues so checking alternator too and relays. Other than that I’m going to think this one through. Found little rust chunks in fuel too.
  5. anthonyar4
    431
    92
    Jun 8, 2019
  6. anthonyar4
    431
    92
    Jun 8, 2019
    All injectors are out and tested good. Put new cups and orings in cause no 4 was pretty beat up.
    baha Thanks this.
