Cat c15 oil leak from behind fan mount?????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AlexCarHauler, Aug 4, 2014.
  1. AlexCarHauler
    AlexCarHauler Light Load Member
    175
    44
    Apr 8, 2013
    Brooklyn NY
    It's what I do, but think I need three nuts))) I can't lose the stud and worry broke a stud
  3. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Stud shouldn't be that tight. If you get scared and can't get it out clean the stud up as much as you can and use black silicon around the stud. I wouldn't fill the hole with it then install stud. Stud first then silicon. I even used a small o ring on the stud and silicon. Easy fix. There is no way dried silicon will ever get out of the oil pan if the screen is where it's suppose to be on the suction tube.
    AlexCarHauler Thanks this.
  4. AlexCarHauler
    175
    44
    Apr 8, 2013
    Brooklyn NY
    it's what i do yesterday, but not sure if that be hold oil. i'm was think about pus some washer over for hold silicon, but is not good idea, fan will be mounted incorect .
  5. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Try the Oring idea. A size or 2 smaller than the stud will stretch and will be small enough to not interfere with the fan hub
  6. AlexCarHauler
    175
    44
    Apr 8, 2013
    Brooklyn NY
    Thanks, will try
  7. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Don't forget the black silicon. That is the secret
  8. AlexCarHauler
    175
    44
    Apr 8, 2013
    Brooklyn NY
    yep, i'm allredy apply black silicon,just was think how to hold them,fan mount have not around hole and can't hold silicon around stud,but oring may help
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    black silicone WITH adhesive. plain black silicone wont hold.
    SAR Thanks this.
  10. AlexCarHauler
    175
    44
    Apr 8, 2013
    Brooklyn NY
    Yep, you right, I have very sticky silicon, second day still on my hands)))))))
  11. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Permatex black silicon is what I was talking about. That's good stuff
    Adisiwaya Thanks this.
