My engine is doing something weird. I bleed the coolant system 100% then let it run a few hours or drive it and I'll lose heat in my cab. I go feel the plumbing and some coolant lines are cold and air locked again!
Compressor new, water pump new, pressure relief cap new, jwac deleted, no cgi, ard on it, old style oil cooler. No combustion gases present, tested with strips and the liquid test.
At full rpm and piping hot, it'll slowly climb to 10 or so psi in coolant tank.
Full engine rebuild 60k ago.
Gonna smash my head against a wall here pretty soon!
Cat c15 Sdp air locking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dustinbrock, Jan 19, 2018.
Page 1 of 7
Not using any coolant, not pushing coolant out overflow either.
Oxbow Thanks this. -
Is there a small #4 line off the top of thermostat housing that goes to top rad tank???
That's there to bleed any air out of system. Sometimes they get hard and plug up...Oxbow and dustinbrock Thank this. -
Oxbow Thanks this.
Ok . Wierd.
Answer me this. Does your truck have any air operated coolant valves for hvac in truck or bunk??Oxbow Thanks this. -
Lower pipe from radiator hose clamp loose sucking air? Air compressor head gasket leaking?
dustinbrock Thanks this. -
Oxbow Thanks this.
Webasto te-ed into the cab lines?
One thing I was thinking about is that the one webasto line is from the cab heater but the T fitting has the hose pointing upwards instead of down. I was wondering if it were causing a venturi effect or if that hose pointing up was having all the air trap in It.
Page 1 of 7
