Did top end on my cat c15 did frist run, leaking oil from both connecting joints on the exhauste manifold. I did idle a lot over weekend was idleing at 900rpm. Anyone ? Cleaned the oil off didn’t leak while running drove 100 miles out
Cat c15 top end done oil form exhauste
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRGHTSD, Apr 30, 2018.
When you say "did top end" you ran the overhead also called adjusting the valve lash correct?
Firgured it out was the excessive blue lubricant that came all over the new head guessing it all broke down started coming out the exhaust
baha Thanks this. -
You mean you didnt clean the cosmolean off the head first before installing it?? Sure hope your head gasket holds.
Expeditor Thanks this. -
Better than opening up a rusty new part any day. I wish more manufacturers followed suit on sensitive engine parts, even though it's a pain in the rump to deal with.Oxbow Thanks this. -
Oxbow Thanks this.
