cat c15 trouble!
Discussion in 'Peterbilt Forum' started by karhauler, Sep 16, 2010.
  1. karhauler
    karhauler Bobtail Member
    sand mtn. Alabama
    1998 cat c15 550 and the oil pressure has increased too high. checked the relief valve on oil pump and NO ONE seems to know what else could cause this!!
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    how high? did you check the guage?
  4. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Check your sending unit... it's unlikely the engine just increased it's oil pressure by itself.
  5. gonzo01
    gonzo01 Light Load Member
    74
    5
    Jun 14, 2010
    denver, co
    Head Gasket;water in oil too?
  6. Texas_incognito
    Texas_incognito Light Load Member
    59
    85
    Oct 9, 2012
    Texas
    My suggestion would be to have the shop put the computer on it and see what the ECM says the oil pressure is. Here' s why. The needle on my volt gauge almost pegged out. Thinking the the charging system was over charging the batteries I went to see about getting it fixed before it damaged the batteries. The mechanic said before we go too far, let's check something. He plugged his computer in and the ECM said the alternator was putting out 13.6 volts. The gauge showed well over 14. The gauge was bad.
